Rajeshwari Jadhav
Check your install.err file.
Please try the following the methods:
Change the PATH System Variable to make sure that C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;… entries are in front of everything else.
Like:  PATH=C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;…all other entries...
Manually register the DLLs listed below by starting a Command Prompt (DOS) "as administrator" and changing to the directory c:\windows\system32, then typing:
regsvr32.exe ole32.dll
regsvr32.exe atl.dll
regsvr32.exe oleaut32.dll
regsvr32.exe scrrun.dll
regsvr32.exe jscript.dll
regsvr32.exe vbscript.dll
Rename .ansys from %TEMP% to old.ansys (just type: %TEMP% in the address bar)
Run the ProductConfig.exe from C:\Program Files\Ansys Inc\v2xx  and configure the application again, by right-clicking the productconfig.exe file and select "Run as Administrator", selecting all options. Make sure you run this as administrator and install all the prerequisites.
Please ty to set the machine language to "English (UK)", and restart the machine. About Windows 10: Open the Windows 10 control panel In the control panel search box, type region Choose the Region link, which should have appeared.
If this does not resolve the problem, we need to check the file size for the downloaded files. It might be that the downloaded files are corrupted, and you may need to download them again and reinstall ANSYS from scratch.
