Ansys Learning Forum Forums Discuss Simulation Fluids Simulating DPM whose droplet material properties not available in database Reply To: Simulating DPM whose droplet material properties not available in database
not.lah.enough
I see. I have some more questions:
  1. In “Set Injection Properties”, what does “Evaporating Species” imply? Is this to connect the specified droplet material (note: I can’t specify it as “nh3-l” in Materials > Droplet Particle) that is later to be vaporized and has to be specified as “nh3-l”?
2. In Multiphase setting, intuitively Eulerian is the proper option, but the option doesn’t show the droplet particle. Checked other Multiphase options, neither seems to be able to connect the phase change with the droplet particle (material). Any workarounds on this one?
