Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Problem with the UDF and the default turbulent viscosity of Realizable k-e › Reply To: Problem with the UDF and the default turbulent viscosity of Realizable k-e
Max
Thank Rob,
I think PHI is in radian.
I compare the torque on the object versus the simulation time which shows the difference in the case of Realizable k-e (see the figure – series 1 is UDF and series 2 is the defaul model) but not for SST k-w.
