Ansys Learning Forum Forums Discuss Simulation Photonics ansys Charge simulation Reply To: ansys Charge simulation
Guilin Sun
Material settings mean the value of the parameters you choose. For example, the "mobility" tab, there are several parameters need to be given correctly under your device working condition.
As for the mesh, you may need to try increase/decrease the max and min edge lengths, tolerance etc.
It is very challenge for us to give specific instructions to resolve this issue, simply based on the error message. " The error code is 9010" can be anything: you can search it online. There are aslo a few posts that you may refer to, for example https://innovationspace.ansys.com/forum/forums/topic/error-when-running-example-of-lumerical-device/
