Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Warning Plugin Error Geometry in Design Modeler › Reply To: Warning Plugin Error Geometry in Design Modeler
Harshvardhan
Plug in error can occur due to imcompatible geometries too. The above mentioned steps are the ones I generally use if I encounter this type of error.
Also, since you are using Design Modeler, try using Parasolid format. It seems to work best with Design Modeler.
I see if I can find some other information to help you out.
In the meanwhile, you can also see the following threads from other users that had similar issue:
Plugin Error
Plugin error unable to attach geometry
PlugIn Error Attach Failed
Unable to attach to geometry file error
I hope this helps.
Harshvardhan
Ansys Help
Ansys Learning Forum (Rules & Guidelines)
