Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Issue with Running LS-PrePost in Batch Mode on an HPC › Reply To: Issue with Running LS-PrePost in Batch Mode on an HPC
Does the linux box have a graphics card?
If No, we need to send display to Xvfb
If it is not installed, you need to install it and can create a X virtual framebuffer.
Please see the below a shell script to create X virtual framebuffer.
#!/bin/sh
# Usage lsprepost_xvfb.sh arguments
# the paramter arguments are sent across to prepost
LSPP_BIN_DIR=/data/cae/grp048/nbak/cae008/ref14/lzqq41/LSDYNA-ONESTEP/Linux/LSPP/lsprepost3.2_opensuse102/
display_id=$$
Xvfb="/usr/X11R6/bin/Xvfb"
LSPREPOST="${LSPP_BIN_DIR}/lsprepost"
export LD_LIBRARY_PATH=$LSPP_BIN_DIR/lib:$LD_LIBRARY_PATH
if [ "x${Xvfb}" = "x" ] ; then
echo "Running LS-Prepost using no graphics mode"
${LSPREPOST} -nographics $@
else
echo "Running LSPREPOST using VirtualFrameBuffer (VFB)"
# ${Xvfb} :${display_id} -nolisten tcp -fbdir -screen 0 1920x1080x64 &
${Xvfb} :${display_id} -screen 0 800x600x24&
pid=$!
DISPLAY=":${display_id}"; export DISPLAY
${LSPREPOST} $@
kill -9 ${pid}
rm -rf /tmp/.X${pid}"-lock"
fi
echo "Done.."
exit
