Ansys Learning Forum Forums Discuss Simulation Fluids Meshing Failure Reply To: Meshing Failure
The more edge settings you use the more likely you'll accidentally have a discrepancy on one or more ends of a surface. I'd tend to look at a good inflation mesh around the airfoil and then use pave to the far field. That also avoids all of the high aspect ratio cells or jumps in cell size between faces.Â
