Ansys Learning Forum › Forums › Discuss Simulation › Fluids › CFD Simulation: Reverse Flow Issue at Outlet2 › Reply To: CFD Simulation: Reverse Flow Issue at Outlet2
jingyuliu
Thank you for your response. Typically, I use the same geometry but with a coarser mesh, which makes it difficult to encounter such an issue. However, after increasing the mesh density by refining the boundary layers, I encountered the reverse flow problem. I'm considering further refining the mesh in the outlet2 area. Does that seem like a good approach?
Best regards,
Leo
