Ansys Learning Forum Forums Discuss Simulation Photonics DGTD band structure calculation Reply To: DGTD band structure calculation
hamid.h.javadi
Concentrating again on Ansys FDTD bandstructure calculation:
I would like to introduce a perturbation in a 1D array of periodic plasmonic nanowire array (analyzed by a unit cell with Bloch boundary condition in 1D).
How can I add perturbion/defect in one unit at the end of the array? Can I calculate the E- and H-fields on the edge surface of the array and introduce it as a source in the perturbed unit? How do I achieve cyclic response between the array and the defect on one end?
Should I calculate the bandstructure to detect the change in mode frequencies? Or reflection minimum as a function of kx?
