Ansys Learning Forum Forums Discuss Simulation Fluids Help needed – Solar calculator, Solar BC boundary conditions Reply To: Help needed – Solar calculator, Solar BC boundary conditions
gopalakrishna.gangisetty
Hello Sir,
Thank you for your response. In this situation, the top side window glass and top side ZnS glass are exposed to solar radiation as they are located in an open environment. I enabled solar BC options (see screen shot please).
However, the bottom side window glass and the ZnS glass on the bottom side are inside the building space and not exposed to direct solar radiation. Given this, should I enable the solar calculator? I would appreciate your guidance on this matter.
