George Karnos
Try the following:
rename the v242 directory that is under:
%APPDATA%\Ansys
to v242.old
now try to run.
If that doesn't work, check firewall software. Try disabling it for a test. then try to run.
Check firewall logs to see if it is blocking the program from checking out a license.
