Ansys Learning Forum Forums Discuss Simulation General Mechanical An unknown error occurred during solution. Reply To: An unknown error occurred during solution.
maabbas
I found this in the file0.err
/COM,ANSYS RELEASE 2023 R1           BUILD 23.1      UP20221128       13:02:35
 *** WARNING ***                         CP =      34.406   TIME= 13:02:44
 Element shape checking is currently inactive.  Issue SHPP,ON or
 SHPP,WARN to reactivate, if desired.
 *** WARNING ***                         CP =      35.609   TIME= 13:02:45
 Material number 13 (used by element 167206) should normally have at
 least one MP or one TB type command associated with it.  Output of
 energy by material may not be available.
 *** WARNING ***                         CP =      38.844   TIME= 13:02:49
 Maximum friction coefficient 0.6 is defined in the model.  Switch to
 the unsymmetric solver (NROP,UNSYM) instead if convergence difficulty
 is encountered.
 *** WARNING ***                         CP =     427.141   TIME= 13:09:18
