Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Setting the angular velocity in 3D when using cylindrical coordinates in Fluent › Reply To: Setting the angular velocity in 3D when using cylindrical coordinates in Fluent
https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v242/en/flu_ug/flu_ug_bcs_sec_bound_cond.html%23flu_ug_sec_vinlet_inputs
In other words if you set both you'll get the sum of the values. So tangential velocity + omega.r (angular velocity).   So, I suggest you choose one or the other.
