Ansys Learning Forum Forums Discuss Simulation Fluids Passive Scalar Mixing: Using UDS To Track Tracer In Batch Mixing Tank Reply To: Passive Scalar Mixing: Using UDS To Track Tracer In Batch Mixing Tank
ll17s5r
Hi, I chose the 'mixture template' which gives water-vapour, oxygen & nitrogen as the default materials. This is a list of the mixture template properties which gives density, specific heat, thermal conductivity, viscosity & mass diffusivity. As I am working with an isothermal system I do not need the specific heat or thermal conductivity.
