Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Passive Scalar Mixing: Using UDS To Track Tracer In Batch Mixing Tank › Reply To: Passive Scalar Mixing: Using UDS To Track Tracer In Batch Mixing Tank
Yes. You will need to alter the template to water and water-tracer (or whatever is in the tank). The only common error is to set the diffusivity to a liquid value as the default is for gases.
