Ansys Learning Forum Forums Discuss Simulation Fluids Problem with the coupling of ANSYS Fluent and Rocky DEM using a UDF Reply To: Problem with the coupling of ANSYS Fluent and Rocky DEM using a UDF
victor.garbe
There are a few requirements in order to make use of UDFs:
  1. You must place all UDF files in the same folder in which your Fluent CAS (CAS.H5 or CAS.GZ)
    file is located. Rocky will then copy those files to the simulation folder and use them during
    the 2-Way coupling simulation.
  2. You must provide the UDF files via one of the following two methods:
    a. By providing the source files. (E.g., the .c, .h, and .cpp source and header files.) In this
    case, you must launch Rocky from an environment that has all the necessary variables
    for UDF compilation. Tip: An easy way to accomplish this is to open a command prompt
    and then call the udf.bat file, which in Windows, is usually located in the following
    folder C:\Program Files\ANSYS Inc {version}\fluent\ntbin\win64 Following this step, you can then launch Rocky from the command prompt. (See also Appendix
    G: Perform Tasks from the Command Line or Journal)
    b. (Recommended) By providing the folder containing the UDF binary files. In this case,
    you must have already compiled the UDF and there are no requirements in terms of
    the environment variables.
What kind of UDF are you trying to use in the Fluent case?
