Ansys Learning Forum Forums Discuss Simulation Fluids Help: Setting of mooring lines Reply To: Help: Setting of mooring lines
Ingrid M
The nonlinear caternary allows you to do this; you can create for the same cable definition different sections with the same (or different) section types, length and specify whether this particular part of the cable is expected to touch down on the seabed.
I hope this helps.
Ingrid
