Ansys Learning Forum › Forums › Installation and Licensing › Ansys Free Student Software › High wing lift coefficient value of a 3D wing › Reply To: High wing lift coefficient value of a 3D wing
October 21, 2024 at 11:08 am
It's a coefficient. Look at the definition carefully, if you didn't alter the reference values you'll get an unexpected result. Alternatively, check you're using air, water can produce a similar effect! If you check the examples in Fluent's Help there are a couple of NACA wings modelled which will show you how to work with the coefficients.
