Ansys Learning Forum Forums Discuss Simulation General Mechanical Coupled field transient of brakedrum Reply To: Coupled field transient of brakedrum
engr.rohan7
Hello Peter,
Thank you for your valuable feedback.
As per your recommendation, I've modelled the brakeshoe-brakepad assembly as shown below,
The frictional contact is same as given in the previous discussion. A revolute joint is given as a pivot for brakeshoe shown below,
The details for the above revolute joint are shown below,
Brakedrum revolute joint-
Bonded contact is defined between pad and shoe interface.
Thermal loads are defined as follows,
Radiation on pads-
Convection on pads-
Convection brakedrum-
Force is given at top end of brakeshoe-
A joint rotation is also defined but it is suppressed for now-
A snapshot of mesh is given below,
I had not shared the details of the time step settings previously, so I've attached the screenshot of the timesteps below,
Please let me know if any corrections need to be made in any of the connections, loads, BCs, mesh, etc. Looking forward to your reply.
Rohan.
