Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Tutorial or Help for 2 way FSI › Reply To: Tutorial or Help for 2 way FSI
In CFD the mesh is the geometry, so you can't change the surface geometry: that means no moving contact with the 6DOF solver. That will also effect any FSI models. If there is a fluid gap, then it needs resolving. You may need to look at a range of content and tutorials as no one source is going to cover everything.
