Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Membrane and bending stresses on a volume (solid) body › Reply To: Membrane and bending stresses on a volume (solid) body
mohan.urs
Hey, to get membrane and bending stress for a solid model you can refer to this Ansys help link 19.5.6. Linearized Stress (ansys.com).
Things to keep in mind while doing this
  1. Keep the general miscellaneous option in analysis - output controls settings turned ON
  2. When you define the path make sure to include a coordinate system where the X axis of the coordinate system points in the same direction of the path created.
Let me know if this works out for you.
Thanks
