Ansys Learning Forum Forums Installation and Licensing Ansys Products Errors with multi-connected bodies using AQWA Reply To: Errors with multi-connected bodies using AQWA
Hilal Çelik
thanks for all your help. I changed the joint type to ball and socket and it did work but I don't understand why it didn't work when they are hinged-type and how I change the tolerance of the simulation?
