Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Most simple material model for non-linear plastic in LS-Dyna Mechanical WB › Reply To: Most simple material model for non-linear plastic in LS-Dyna Mechanical WB
douk.van.werven
Hi Armin, thanks for this input. I would like to use this model for my simulation. Where can I find information how to input my engineering stress strain curve into this model? If I understand correctly, I have to break it up into true stress and plastic strain. Is that correct? Is there any documentation on how to convert the experimental data so that it can be input for the material model? Is there information available how to determine the end of linear part?
