Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Mass-spring system does not move properly when the spring is non-linear › Reply To: Mass-spring system does not move properly when the spring is non-linear
October 18, 2024 at 12:05 am
Right, it is a full transient analysis. In fact, I have created a probe point to verify the motion of the spring's mass. It gives me zero for all instants of time:
In case it helps, these were the paramers set for the non-linear spring and the analysis:
Could you share your simulation file, so that I can understand why in your case the non-linear spring works properly?
