Ansys Learning Forum Forums Discuss Simulation Fluids Reversed flows after switching inlet boundary conditions Reply To: Reversed flows after switching inlet boundary conditions
The sources may just need some very careful management. Part of the problem may be that as you remove mass & add heat for the process you cause more/less mass to be removed because the temperature changes: have a look at the Fluent phase change models (Eulerian and Eulerian Wall Film) models.
