Ansys Learning Forum Forums Installation and Licensing Ansys Products The directory does not exist Reply To: The directory does not exist
Hongtian CHEN
You assumption is correct, the user name can only be English, what you should do is changing your user name or just create a new accout using an English name, and then install the software again.
