Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › the error “AROOTL:CALSSB FAILED” › Reply To: the error “AROOTL:CALSSB FAILED”
October 17, 2024 at 9:46 am
Sorry I did not explain very well: click on the structure under Geometry in the Outline tree (see below - here named 'Barge'), and in the Details panel you should find 'Calculate Shear Force/Bending Moment' at the bottom of the settings.
This setting will not affect the simulation results, it will only change the availability of some results in the Hydrodynamic Diffraction system, i.e. you will not be able to plot RAO-based shear forces/bending moments.
Mike
