Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Contact issue in 2D analysis › Reply To: Contact issue in 2D analysis
October 17, 2024 at 8:29 am
mohan.urs
Hey,Â
Sorry but I couldn’t understand what was your intended result. If possible can you explain it through a picture.
And another thing is you’ve expalined modifying contact pin ball radius settings, can you point out for which contact you have modified them, I do see that there is only one contact possible which is having a gap but i just want to confirm that and if you are usig bonded contact for that, that might be the issue. You can try using frictionless at first and then modify it to frictional when the results start making more sense to you.
Thanks
