Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Unable to modify the source in the terahertz band in Grating S parameters › Reply To: Unable to modify the source in the terahertz band in Grating S parameters
Serein
Thank you very much for your reply. I may not have described my issue clearly, which might have led to some misunderstanding. My question is that when I directly modify the frequency of the variable source in the S-parameter analysis group, I still see the frequency as 1e-12 THz when checking the source, which is clearly incorrect. For example, in the image below, I set the frequency of the S-parameter variable source to 10 THz, but the setting in the source remains unchanged at 1e-12 THz. I look forward to your response. Thank you.
