Ansys Learning Forum › Forums › Discuss Simulation › Fluids › 1 WAY COUPLING WITH ROCKY › Reply To: 1 WAY COUPLING WITH ROCKY
Hi Lucas and thank you for your suggestions.
Basically the fibers are short, in fact they are faced cilindrical with a diameter of 0.2 mm and a vertical aspect ratio of 65 (so their length is 13 mm).
I'm trying to change their orientation respect to the global system, maybe along the X axis.
I would ask you an information for the mass flow value.Since that inside the domain I have a specified percentage of fibers to fill it with a certain time, how could you suggest me to calibrate the injection?
The cfd analysis lasts 17 seconds.
I don't know if I need to calculate by myself the effective massflow by Knowing the velocity from which the fibers are moving ( mass flow = area of inlet * velocity * density of fibers ) and after that deriving the total time ( Wich will be lower than 17 seconds) required to produce the total amount of fibers.
The second way that I thought is to apply an injection time equal to the cfd analysis (17 seconds) and calibrate the mass flow in kg/s in order to generate a total amount of fiber close to the 1.5% of the volume.
I'm waiting for some information,
Best regards
Ivan
