Ansys Learning Forum Forums Discuss Simulation Fluids Help: How to link the primary and auxiliary fluid cell in non-equibrilium model? Reply To: Help: How to link the primary and auxiliary fluid cell in non-equibrilium model?
yf70512
Hello Rob,
The code can not run and the fluent crashed with error "999999: mpt_accept: error: accept failed : No such file or directory". My UDF was following:
DEFINE_SOURCE(Solid_source,c,t,dS,eqn)
    real Tf, Ts;
    real hfs = HFS_CONSTANT;  // Placeholder value for heat transfer coefficient
    real Afs = AFS_CONSTANT;    // Placeholder value for interfacial area density
    real source;
    const char sv_t;
    // Obtain fluid and solid temperatures
    Ts = C_T(c, t);  //
    Tf =  C_DHX_NBR_T(c,t);
    // Calculate the source term based on the modified expression
    source = hfs * Afs * (pow(Tf, 4.0) - pow(Ts, 4.0));
    // Set the derivative of the source term with respect to Tf
    dS[eqn] = - 4.0 * hfs * Afs * pow(Ts, 3.0);
    return source;
The maro "C_DHX_NBR_T(c,t)" is in the header file "dual_cell.h". But the fluent also crashed with the same error. I am not sure if it is able to modify the energy source of the non-equibrilium model. The error "999999" always occurred.
