Ansys Learning Forum › Forums › Discuss Simulation › Fluids › 1 WAY COUPLING WITH ROCKY › Reply To: 1 WAY COUPLING WITH ROCKY
Lucas Bertollo Baggio
Hello Ivan,
Please check your particle size and orientation.
The fibers might be overlapping to the walls around the inlet.
  • try to reduce the size significantly
  • try to rotate the fibers in 90 dega
  • try to put the surface outside the walls
let me know if it worked.
Best regards,
Lucas
