Ansys Learning Forum Forums Discuss Simulation Electronics How to determine initial position in motion setup Reply To: How to determine initial position in motion setup
Ivonne Marti
Hi Purity,
It is hard to say without checking the model. But maybe there is a mistake in the simulation setup. To be sure your setup is correct, you can open the installation example “Interior Permanent Magnet” and check that you have a similar setup.
You can open the example going to: Open Examples/Maxwell/Electrical Machines -> Interior Permanent Magnet
Please note that if you are computing the cogging torque using the Magnetostatic solver,  you need to specify the torque calculation in the Parameters/Torque and include all moving parts (rotor, magnets, shaft).
I hope this helps you
Ivonne
