Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Solution combination for Random vibration and Static Structural › Reply To: Solution combination for Random vibration and Static Structural
October 16, 2024 at 1:31 pm
Usually it's just the vibratory stress that is considered in a Fatigue analsyis. So no need to combine the static stress with the PSD stress. If you have an S-N curve defined in Engineering Data, the gui will support computing a damage factor based on the duration of the event or a life time.
