Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Integrating Fluent Pressure Data into Mechanical for Riverbed Soil Stress Analys › Reply To: Integrating Fluent Pressure Data into Mechanical for Riverbed Soil Stress Analys
Rahul
Hello
You can transfer the Fluent pressure data into Mechanical by following approaches:
  1. Using imported loads for one-way FSI. Direct schematic connection between Fluent and Mechanical: Using Imported Loads for One-Way FSI (ansys.com)
  2. Using system coupling: 5.15.17.5. One-Way FSI Transfers Using System Coupling in Workbench (ansys.com)
  3. Export the pressure data from Fluent and import it in Mechanical using External data.
