Ansys Learning Forum Forums Discuss Simulation General Mechanical Facing Problem with defining Boundary condition Reply To: Facing Problem with defining Boundary condition
Rahul Kumbhar
Hi Abhinav,
I think remote displacement is not appropriate. You can define a cylindrical coordinate system in the centre and use Displacement to apply the constraint in the radial direction and tangenetial direction. In tangential direction, it would be arc length (S=r*theta). This will depend on radial distance of each node from center. So you may give a tabular data using X(radius) as independent variable.
