Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Gobal name System not defined or DataModel or MechanicalEnum not defined › Reply To: Gobal name System not defined or DataModel or MechanicalEnum not defined
			October 16, 2024 at 10:00 am
Ansys employees can not debug the code on forum, but can you please add more details such as images and some more description? when the code works, are you running it in the same way? I am sure you may have used and heard before, but please try using rubber duck debugging to check each step in your code. If you can simplify your code and add it here that would be useful.
-Aniket
