Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Discrete Element Method (DEM) › Reply To: Discrete Element Method (DEM)
gentleman1990
Dear Ram,
Thanks so much for your prompt response. Can you elaborate on how your proposed method can be implemented? Is that through the command line or any other way? I have never used this approach. If a document/tutorial shows how the "sudo routine" implementation works, I can also read it. Sorry in advance if my request is dumb.
Best Regards,
M
