Ansys Learning Forum Forums Discuss Simulation Fluids Reversed flows after switching inlet boundary conditions Reply To: Reversed flows after switching inlet boundary conditions
thaison.tran
I checked the inlet total pressure at every time step in the report file, and even manually stopped the simulation to set the gauge total pressure equal to or slightly higher than the current value (0.46 bar). Interestingly, the switch is pretty smooth with reversed flows last for a few time steps in the case without the adsorbent material in the tank.
