Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Odb ++ import issue › Reply To: Odb ++ import issue
October 15, 2024 at 3:00 pm
If you are using Classic Icepak, the solder layer will be ignored. Please manually create the solder layer using a block object. In AEDT Icepak, solder layer can be imported into PCB component.
