Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Acceleration Range in Harmonic Analysis › Reply To: Acceleration Range in Harmonic Analysis
rani.a
A further doubt from the previous results I just recieved.
After solving, I have received a result that is not acceptable and I would like to know the reason/corrections needed.
The body that is supposed to be moving inside due to vibration and is moving outside the enclosure during the vibration.
The body in red are supposed to be foam material to prevent deformation from vibration & shock, but they are also over-expanding/over-compression than the reality requirement.
How can I restrict this vibration movement to within inside enclosure. Is it something to do with the contacts.
Also, the top brackets that are mounted on top of the blocks are mounted by bolts to the welded to the outer body are also moving outside the nut areas which are not supposed to.
Please help me with this issue as well to check on a smooth solution as per requirement.
