Ansys Learning Forum Forums Discuss Simulation General Mechanical Contact Problems: Curved Surface and Plane Interaction in Simulation Reply To: Contact Problems: Curved Surface and Plane Interaction in Simulation
tiwari15abhinav
Hi, I think the program controlled settings work best for the contacts. However, if you still see some penetration try giving contact sizing and try refining the mesh in the contact surfaces.
If these contact settings wouldn't work i will go with:
  1. Contact formulation : Augmented Lagrange
  2. Detection Method: Nodal Normal to target
  3. Penetration tolerance turned on with low value of tolerance
  4. stiffness : Factor
  5. Stiffness factor: if both clip and plane are same material Use 1 if one material is soft use 1e-2
  6. update stiffness: Each Iteration
  7. Pinball radius : Program Controlled
  8. Interface Treatment : add offset, No ramping
