Ansys Learning Forum Forums Discuss Simulation General Mechanical Acceleration Range in Harmonic Analysis Reply To: Acceleration Range in Harmonic Analysis
rani.a
Thank you Erik & Mohan for the response, I shall try it after my solving is done.
Also, this is the values of acceleration that can be added w.r.t the frequency, right. But, I have a frequency range of 7Hz-18Hz with 10mm/s2, 18-25Hz with 10-20mm/s2 and 25-200Hz with 20mm/s2.
How can I give a value for a logarithimic sweep. Attached below is the snapshot of the analysis settings, I used.
Awaiting for a quick response.
Rani
