Ansys Learning Forum Forums Discuss Simulation General Mechanical Mesh problem in thin-film construction Reply To: Mesh problem in thin-film construction
mohan.urs
Hey,
Can you once right click on the error and press "go to problematic geometry" and confirm what is the error ?
Sometimes there are geometry errors (small faces inside the volume) that get carried on to mechanical and show up as errors like you are getting. If this is not the case, do post some pictures of geometry and mesh parameters that you are using so other forum members can provide meshing suggestions.
Thanks.
