Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Unable to attach geometry 2024 R2 › Reply To: Unable to attach geometry 2024 R2
Sampat Kumar
Hi Som,
Can you try to reconfigure the Ansys as well as Spceclaim?
Can you try to reconfigure the Ansys by using %appdata% and %temp%. Let's assume if you have the Ansys 24R2 version.
1. Open a file explorer and type %appdata% in the address bar. Locate the Ansys folder V242 and rename it to V242.old.
2. Open a file explorer and type %temp% folder. Search for ‘.ansys’ folder and rename it to ‘.ansys.old’ then launch the application.
After doing so, enter the %localappdata% in the address bar of File Explorer, rename the SpaceClaim folder, and let me know if this helps.
Best Regards,
Sampat
