Ansys Learning Forum Forums Discuss Simulation General Mechanical Sliding mechanism analysis for stability Reply To: Sliding mechanism analysis for stability
balaji.bp
Hello Sir, thanks for the reply.
Yess in first approach I have scoped the end faces of two slides for applying 100 mm displacement.In this I have applied X displacement to end surfaces and Y and Z kept zero may be because of that its happening.If it so then what is the way to apply motion and see the end stresses in both the analysis having less difference)
In both the cases point mass is scoped to the 4 holes surfacse which are present on both the slides.
Thanks in advance
