Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › LS-DYNA Simulation Termination Cycle Reached › Reply To: LS-DYNA Simulation Termination Cycle Reached
Alex Rycman
Please verify a value under ENDCYC in *CONTROL_TERMINATION.
Some suggestion, running a simulation for 10M cycles is not recommended due to the round-off error. Could you please check if times step can be increase by activating mass scaling in the model |DT2MS| flag in *CONTROL_TIMESTEP? To minimize the round-off error please consider using a double precision solver.
Please let me know if that helps.
Thank you,
Alex
