Ansys Learning Forum Forums Discuss Simulation Electronics Optislang MotorCAD HPC integration Reply To: Optislang MotorCAD HPC integration
nkb221
Hi Akeel,
Thank you for your response. In the first instance, I've used the tutorial and template model to generate an optislang project. I've tried running the project with a single instance at a time and I found that MotorCAD was incredibly slow as opposed to manual computation. Task Manager states that CPU usage for MotorCAD is below 1%. I've added another ticket for this https://innovationspace.ansys.com/forum/forums/topic/optislang-motorcad-single-instance-integration/
I've then tried adding the setting for number of instances in parallel but this did not lead to multiple instances of MotorCAD in Task Manager or any improvement in speed.
