Ansys Learning Forum Forums Discuss Simulation Fluids What is the difference between total heat transfer rate and total surface heat f Reply To: What is the difference between total heat transfer rate and total surface heat f
Yes, that's why it's in the Wall Fluxes section.  Use the Flux reports for all surfaces when judging where heat goes.  Note, you may see a non-zero heat flux on the inlet based on it's temperature and material properties.Â
