Ansys Learning Forum Forums Discuss Simulation Fluids What is the difference between total heat transfer rate and total surface heat f Reply To: What is the difference between total heat transfer rate and total surface heat f
sjyang
I gave you the wrong answer on October 11th, and I sincerely apologize. What I'm actually curious about is not why a wall function doesn't agree with a flux definition on an inlet, but rather why the surface integral of the total surface heat flux and the total heat transfer rate in the flux report output different values at the inlet.
I am attaching a screenshot of the phenomenon. Please take it into consideration. Thank you
[The surface integral of the total surface heat flux]
[The total heat transfer rate in the flux report]
